Engine build
So after looking into the engine side of things what will and won’t work
this is the spec I’m going for ( May be tweaked )
200 block long studded
standard crank ( polished )
Arrow rods
big wing sump
mild ported head
BD14 / 16 cams ( or similar)
BE 7670 with nortech manifold
hart inlet
wasted spark kit
what sort of figures would I be looking at with this type of setup
was hoping for 570 as been told it’s a sweet spot for a road going Cosworth
cheers guys.
Arrow rods
big wing sump
mild ported head
hart inlet
wasted spark kit
cheers guys.
I think the biggest decider if your after the most power and torque you can get from the turbo set up your using. Has to be from what I can gather is compression ratio head spec cam spec and who maps it. Anyone can bolt an engine together but them factors all working together is what gets you the results
So will you be building the engine yourself or are you having it done ?
Interested in this as more power is next on my list as have reached the safe limit of my engine as it's not long studded at he moment
ive built a lot of engines but it was 20 years ago
I’ll be getting a good machine shop to that side of things
so not sure yet
i think I’ll strip and inspect and go from there
let me know how you get on.
bagginsRSturbo
22
Nov 20, 2012 08:46 PM
Adam.
Sep 21, 2011 12:52 PM
JanDK
13
Dec 15, 2010 01:09 PM
jacko
32
May 22, 2006 08:45 AM
Mark_w
17
Oct 1, 2004 05:02 PM
