Fiesta rs turbo turns over but no ignition
hi all
have an issue where my car will turn over but there are no ignition lights on the dash and won’t start because of this
looked through all of the wiring as best as I can but I can’t see any issues, fuses all look ok. Wires are all correct at the back of the barrel so I’m stumped
any ideas pls
any ideas pls
Ignition relay suspect mate. Will more than likely be a relay in my experience. Put the ignition on and play about with the relays and see if it comes on. Had a breakdown the other day with same fault
jason1987
Ford Mondeo Including ST
18
May 10, 2014 07:58 PM
snOOpy86
24
Sep 23, 2004 06:22 PM
