Mondeo MK3 2lt TDCI Clutch Pedal Gone Stiff?
Old Nov 10, 2018 | 04:44 PM
Tidon's Avatar
Tidon
Default Mondeo MK3 2lt TDCI Clutch Pedal Gone Stiff?
As the title says. I went to drive the car last night and noticed the clutch pedal were really hard when pressing it down but still ok to drive.
I think the biting point is a bit lower than usual as well. It were fine when i parked up?
Any help appreciated..
Old Nov 11, 2018 | 08:54 PM
Tidon's Avatar
Tidon
Apparently it's the clutch slave cylinder that's gone..!
Old Nov 20, 2018 | 09:02 AM
I've done one before where I've lowered the gearbox side of the sub frame down and removed the gear box and rested it in the gap between the sub frame and chassis leg then there is just enough room to get your hands in to remove the clutch and slave cylinder
Old Nov 20, 2018 | 12:32 PM
Tidon's Avatar
Tidon
Just got the part so when I do it I'll try it your way.. Thanks
Old Nov 20, 2018 | 03:02 PM
Are you replacing the clutch as well as the slave cylinder.
Old Nov 21, 2018 | 11:53 AM
Tidon's Avatar
Tidon
I'm just replacing the cylinder as the clutch were replaced nearly 2 years ago so it should be still good to go..
Tony_R
Oct 15, 2010 08:13 PM
confused.com
Ford Escort RS Cosworth
Jan 22, 2008 08:41 PM
