wiring ECU RS 2000 mk5
Old Oct 29, 2018 | 07:50 AM
jgijon59's Avatar
jgijon59
jgijon59
Smile wiring ECU RS 2000 mk5
Hello,
First of all thanks to let me ask this question on this forum.
I'm trying to fit on my Ford Sierra dohc 2wd a Rs2000 engine N7A, after so many hour looking for info and wiring loom complete from Escort RS 2000 wiring loom complete..
I haven´t got lucky, is so difficult to find it,
Have any body the Ecu Diagram? I need to know what I have to modify on Ford sierra`s Wiring in order to matching with the Rs 2000 engine and ECU.
the car will be driven on Off Road Rally and Marocco Challenge and so on,
Old Oct 31, 2018 | 09:40 AM
jgijon59's Avatar
jgijon59
jgijon59
hello...
Old Oct 31, 2018 | 06:56 PM
big_wasa's Avatar
big_wasa
I have done all sorts of fords but not the i4. Weight and the costly camchain meant I went the Zetec path.
one I did earlier
https://passionford.com/forum/restor...n-frs-ecu.html
have you got the Rs 2000 ecu and loom ? If not it’s a non starter as there won’t be enough pins in the Sierra ecu to modify.
If you have, look at the pcm / ecu plug it is numbered 1 to 60. If you list 1 to 60 with the colour of the wire next to it I will look up what wire does what on a program I have. I need the colours as the program will list multi options depending on Pats or non pats and other things.
for example
pin 1) orange / yellow trace is kam ( keep alive memory ) permanent 12
pin 2) no wire.
pin 3) white / violet trace is the speed sensor in the gear box.
pin 4) no wire
pin 5 depends on pats and so on.
kalvin_uk
17
Mar 13, 2025 08:32 AM
rsstav
Jun 18, 2015 08:26 PM
rallyfun
Escort MK 5 / MK 6
May 16, 2012 06:43 AM
rsguy
Feb 8, 2009 03:57 PM
