can you stick metal instead of welding it on a car?
Old Oct 22, 2018 | 03:41 PM
paceo's Avatar
paceo
Talking can you stick metal instead of welding it on a car?
General question, done a lot of welding on my old golf, but come to a part right up in the filler cap area thats hard to get to and would be a total arse trying to weld a small plate in, ive managed to powerfile the rot out which is only about the size of a 50p and made a nice fresh plate of metal up that fits flush.
so my question is instead of welding the plate in, can it be stuck in and what would you use to stick it? seam sealer? i also use epoxy primer on bare metal. reason i ask, im sure over on FT.com a guy done a restoration on a fiesta rs turbo by sticking some panels together, sure his name was gregg, was the red fiesta rst?
Old Oct 22, 2018 | 03:54 PM
Caddyshack's Avatar
Caddyshack
JB weld or liquid metal would do it and then cover the area in seam sealer. I am not sure how this would be with MOT so I would paint it after the seam sealer dries and then nobody should see it.
Old Oct 22, 2018 | 04:42 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Bond it. Windscreen glue with the proper metal primer would be a good one. I’m sure there’s a proper bond body shops use
Old Oct 22, 2018 | 04:55 PM
For mot if you can't see the repair they can't do nowt about it.
Old Oct 22, 2018 | 09:13 PM
mk1turboestate's Avatar
mk1turboestate
I have been considering using this https://www.ebay.co.uk/itm/Car-van-b...y/221240120421
to bond on the valance of my metro but I'm undecided, it's the stuff you would use on a modern quarter panel etc, I like the idea because I could clean up the metal perfect and bond and seam seal at the same time so water can't get in,
Old Oct 23, 2018 | 05:51 PM
zetaboostboy522bhp's Avatar
zetaboostboy522bhp
Tiger seal it in , it won't move then , just key both plates up and spread it well.
cheers paul
Old Oct 24, 2018 | 11:46 AM
lacey's Avatar
lacey
If it's ain't structural then it should not cause
a problem with mot,s
there are a fair few bonding agents available now
and some can be as strong as weld
lecky12345
Jul 17, 2012 11:37 PM
RSTurboSI
Sep 3, 2009 11:36 AM
andre_k
Jun 24, 2009 08:52 PM
Jasesapphy
12
Apr 26, 2008 08:41 AM
38
Jul 22, 2004 12:20 PM
