Lambda sensor
Old Oct 21, 2018 | 03:44 PM
Marc sierra's Avatar
Marc sierra
Default Lambda sensor
I just noticed that my 4x4 Sapph has a plug in the turbine housing next to the standard lambda sensor. Can this be used for a second (wideband) lambda sensor? Or does it have a different purpose?
Old Oct 22, 2018 | 12:29 PM
Marc sierra
Stole a picture from somewhere to show what I mean. The normal lambda sensor goes where the hexagonal bolt is, but the plug with the allen key hole is not used. Can it be used for a second lambda sensor?
Old Oct 22, 2018 | 03:22 PM
R4N SS's Avatar
R4N SS
i dont see why not - ive got my lambda sensor in the downpipe at the top
Old Oct 22, 2018 | 03:35 PM
Caddyshack's Avatar
Caddyshack
Most of them tend to be in the down pipe and you can just buy weld on lugs. If that thread is the same as a lamda and it sits in exhaust flow then you could use it.
davidnormanuk
Nov 2, 2012 09:56 PM
Roosie
May 6, 2007 09:23 PM
Roosie
Jul 26, 2004 07:20 AM
XRTypeRS
Jul 18, 2004 12:34 PM
ian.gordon
Jul 8, 2004 06:58 PM
