MK4 escort zetec silvertop wiring help needed
Hi I've got a 1.6 zetec silvertop from a v reg escort with pats (I've got the transponder and key and ECU and loom) to be fitted in my MK4 escort 1.4 carb . Just wondered if anyone can tell me where the wires off the zetec loom goto on the MK4 ?
HI, Can you expand on what wires you have from the Zetec loom? If its a 1.4Carb it will need a EFI fuel tank with in tank pump, or an XR3i / RS Turbo MFI tank with pump, accumulator ect.
You will then need to wire in as per the normal RS turbo conversion to include a fuel injection relay, a fuel pump relay and an Ignition feed, Permanent feed and a couple of ground wires.
Not sure on the RPM output on the Silvertops but you may need to do something with the rev counter,
There is quite a bit to do.
Rich
Rich
HirenRS
Oct 8, 2012 06:11 PM
gklhso
Aug 9, 2009 02:03 PM
