Rs turbo ofab conversion
Old Oct 14, 2018 | 05:48 PM
Mikeyward's Avatar
Mikeyward
Default Rs turbo ofab conversion
I have fitted a fiesta rs turbo engine loom to my s1 rs turbo to convert to efi but was wondering if you have to change the pins on the ecu or is it you only have to change them if you use the xr3i loom
Old Oct 15, 2018 | 01:28 PM
Mikeyward's Avatar
Mikeyward
Anyone got any input on this cheers
Old Oct 30, 2018 | 10:58 AM
90_spec's Avatar
90_spec
HI Mike,
I have just done this conversion on a 1.1 bonus and will be firing up at the weekend,
If all goes well, i will share my detailed wiring diagram with you.
I have used an XR3i EFI main harness and an OFAB ecu, with XR3i EFi fuel tank but you can use the S1 tank, Do you have an OFAB Map sensor and Air charge sensor?
Thanks
Rich
paceo
Jul 14, 2009 11:51 PM
mrorange2
Jul 2, 2008 06:02 PM
GUZZLER
May 29, 2007 05:02 PM
black_FRST
21
Apr 8, 2005 10:35 PM
