Cosworth boost controller help?
Old Oct 11, 2018 | 06:15 PM
3drRich's Avatar
3drRich
Default Cosworth boost controller help?
We recently installed my emerald management in my track car but I have now found what I believe to be a boost control valve of some sort in my many boxes of bits (pic below) as I remember removing it from the previous car and I know it was plumbed in.
My questions are I don’t remember any additional switches in the car that would control the valve so would it just be 1 setting that’s run straight to the ecu? I have the wiring diagram for the ecu and it shows where the boost controller was connected but I don’t know if it went straight to the boost valve or if there would have been a switch or something. I intend on running some sort of 2 stage boost so don’t know if this will or would do the job.
On the ports it has NC, NO, COM and I know only the turbo and actuator where connected to 2 of these.
Any help would be appreciated.
Old Oct 11, 2018 | 06:41 PM
Caddyshack's Avatar
Caddyshack
Why not ask Dave at emerald, he is ace at helping
Old Oct 11, 2018 | 06:42 PM
Caddyshack's Avatar
Caddyshack
My standard ecu had one like
yours but then it had a greddy boost controller
Old Oct 11, 2018 | 07:11 PM
3drRich's Avatar
3drRich
I was going to contact emerald but thought I’d post on here first to see if anyone knew.
Old Oct 11, 2018 | 09:03 PM
stevieturbo's Avatar
stevieturbo
C**t
Really, unless you know what was there before, or what was controlling it...there is no sense guessing.
You need to find out if the ecu was controlling boost in the past or if someone had fitted a boost controller that is no longer there etc etc. But the simple/easy thing to do is use the ecu to control boost, although obviously this will need setup/tuned within the ecu and the engine tuned at all boost levels you will use.
If for whatever reason that is not possible, there are dozens of aftermarket controllers on the market, although most will come with a new valve anyway. The connector etc on yours does look more akin to a Greddy unit.
Connection here shows for a typical 3 port MAC valve. As to whether numbering on your valve is identical, would be up to you to determine. Ignore the block off unused port part. 2 port internal actuators like that arent that common anyway.
Old Oct 11, 2018 | 09:11 PM
3drRich's Avatar
3drRich
Thanks stevie. I think it was an aftermarket unit like Greddy as you say but I don’t want to run this so think my best option would be to re install the Amal valve and switch it as this seems to be a popular setup.
Old Oct 11, 2018 | 09:20 PM
stevieturbo
C**t
I would prefer good boost control, to antiquated boost control.
Old Oct 11, 2018 | 09:28 PM
3drRich's Avatar
3drRich
So you wouldnt go the Amal valve route?
Old Oct 11, 2018 | 09:30 PM
3drRich's Avatar
3drRich
Who I’m getting to map it put there own kind of boost controller on it and it’s wired back to the ecu where they adjust it from there so maybe best for me to leave it for now as it won’t hurt to get the car running without any of that.
Old Oct 11, 2018 | 09:36 PM
stevieturbo
C**t
From what I understand, the Amal valve is a simple fixed bleed via an off/on strategy ( whether manual switch or via ecu ), so it is very limited in what it can do vs a properly controlled solenoid/PWM control where you can map it throughout the operating range of the engine.
So with a suitable controller you could have boost by speed, rpm, gear, etc
But your statement above suggests there is already a form of boost control in place via the ecu, so surely you would have no need for this valve nor an Amal valve ?
Of course...simple can work well too ( with no valves at all, gate only )...really just depends what is wanted or needed.
Old Oct 11, 2018 | 09:46 PM
3drRich's Avatar
3drRich
Ok that’s interesting. I’m really struggling to remember how it was set up in the car I removed it all from. There must have been an aftermarket boost controller but I guess unless I remember that’s no help. I think I will leave it for the time being and get the mapper to sort it out. I’m only looking to fire the engine as we have just installed all the new loom and fuel system.
Old Oct 12, 2018 | 05:37 AM
Marc sierra's Avatar
Marc sierra
Regarding the text near the ports, the COM will probably mean Common, so it will be the supply line of air (compressor). The NC will mean Normally Closed and the NO Normally Open.
To connect it in a safe way I would expect the NO should be connected to the wastegate and the NC should be open to atmosphere. In that case the valve needs to be actuated to bleed off air in order to increase the boost. Of course the question is also whether the valve is controlled in this way by the ECU. But it probably also needs some restrictors just like the amalvalve in order to set the boost levels.
Old Oct 12, 2018 | 09:12 AM
Caddyshack's Avatar
Caddyshack
Emerald ECU does control the boost; Same as my VIPEC, I do not have anything in terms of the solenoid, amal valve, air injectors etc....I also do not have a dump valve, not that this is exactly related.
Old Oct 12, 2018 | 02:01 PM
stevieturbo
C**t
With proper boost control via ecu/controller and solenoid/PWM valve, there is rarely any need for restrictors or anything like it, unless there is something badly wrong or mismatched with the parts.
Old Oct 12, 2018 | 02:38 PM
Mark Shead's Avatar
Mark Shead
you have a dump valve and solenoid on the nose of the turbo.
Mark
Old Oct 15, 2018 | 04:27 PM
Caddyshack's Avatar
Caddyshack
Mark
ah, good point, I meant a plumbed in type like a Bailey, aftermarket Jobbie.
oit of interest Mark, is there no real benefit in running re-circ or where does the Borg Warner "dump" to?
Old Oct 15, 2018 | 04:54 PM
stevieturbo
C**t
BW is a re-circ.
Or just run none at all.
Old Oct 15, 2018 | 05:03 PM
Caddyshack's Avatar
Caddyshack
Originally Posted by stevieturbo
BW is a re-circ.
‘I did wonder if it was, I hadn’t paid attention to see where the air would go back in.
D-Sport
Apr 8, 2010 01:13 PM
ASHCOSSIE
Apr 15, 2009 11:02 PM
Daz_Crystal Blue Saph
Jul 28, 2007 08:17 PM
richard_xr2i1800
Jun 1, 2006 12:20 AM
scooby8272
Nov 14, 2004 06:37 PM
