Rouse boot Spoiler for Sapphire Cosworth
Im looking for a rouse boot spoiler for my Sapphire, is the any adresse where i can buy a good one?
A little more downforce at rearend would be great..
Ah there is a Jay...
Can you offer a rouse Spoiler for sapphire and will they have a little more downforce?
Oversteering behind 250 km/h are not really funny at the our "Autobahn"
I have allmost everthing done,
Coilovers special for this Car from H&R Suspensions
Poly Bushes everwhere
Uniball Topmounts at front...
And its only at Highspeed, i would like some oversteering but not at hishspeed..
Do you already have a 6 degree rear beam? That will help with the handling too. It will mostly cure understeer, but it also makes the rear less snappy. With less understeer from the suspension geometry you are able to run softer rear springs which might help with the oversteering at high speed.
Do you have some aerodynamic help at the front already, like a Rouse splitter? As I wouldn't expect the aero of the standard car to be such that it gives oversteer at high speed.
charlie luciano
May 26, 2010 07:06 AM
