VIN identification
Old Oct 8, 2018 | 03:19 PM
Brocker's Avatar
Brocker
Default VIN identification
Can anyone help me to find informations about a VIN Number?
WF0EXXGBBEGU94470
It should be a 3 door Sierra Cosworth, but i don't find anything about it, and have no document of it.
Old Oct 8, 2018 | 05:05 PM
MONSTER's Avatar
MONSTER
It's definitely a 1986 3 door Sierra buts thats as far as I can say from just the number.
Do you have access to the VIN plate?
Old Oct 8, 2018 | 06:52 PM
Brocker's Avatar
Brocker
No it was a barn find, no documents no plates
Old Mar 31, 2020 | 07:43 AM
Brocker's Avatar
Brocker
Fortunately i found the plates...
Maybe we can get some more informations now?
Old Mar 31, 2020 | 09:01 AM
bigdel's Avatar
bigdel
These are my VIN plates, so yours should look identical to these with the exception of the colour.
I can see a very obvious difference between yours and mine straight away in the 4th box down on the silver plate. Mine says 1700, yours is N1H1L, and also the vslue in the 'Type' box is different.
Dunno what those refer to, but I'm sure someone will.
Old Mar 31, 2020 | 07:26 PM
qed296's Avatar
qed296
Manufacturer Identifier: WF0 Ford Werke A.G. (Germany)Ford Werke A.G. (Germany)
Body type: 3 Door Hatchback
Line: Ford Germany (Own Assembly)
Assembly Plant: Genk (Belgium)
Model: Sierra
Year: 1986
Month: June
Production Sequence: 94470
N5 = 2.0 Dohc
J = Man T5
3 = 3.64 diff ratio
Old Apr 1, 2020 | 04:47 PM
clairendave's Avatar
clairendave
Dave not Claire.
the 1700 figure is gross weight and the same figure in the second box, or the letters and no figure just means it's not type approved for towing.
Old Apr 2, 2020 | 03:29 AM
4x4kiwi's Avatar
4x4kiwi
Brocker
Send me your email address by PM and I will send you the breakdown information for the plates. I did post it on here a while ago but had to take it down under the threat of being sued. Go figure.
Cheers David
swoosh500
15
Nov 17, 2020 01:43 PM
cozziepj
May 18, 2009 06:36 PM
philyS2
Dec 24, 2008 04:03 PM
slicktimmy
15
Jul 19, 2007 09:36 AM
tansey
Jul 24, 2005 01:04 PM
