Mk5 RS2000 alloys on Mk4, Which Wheel Bolts??
Old Oct 8, 2018 | 09:41 AM
90_spec's Avatar
90_spec
Default Mk5 RS2000 alloys on Mk4, Which Wheel Bolts??
Morning all, Ive a set of Mk5 RS2000 alloys on my Mk4 escort, currently fitted with standard RS turbo wheel bolts, however, the Chamfer on the RS2000 wheel nuts is much shallower allowing for more surface area on the alloy centre,
Has anyone else fitted these alloys to a Mk4 and if so, which wheel bolts did you use? as the Std Mk4 RS turbo wheel bolts are definitely not a good enough fit.
Many thanks
Rich
Old Oct 8, 2018 | 09:47 AM
R4N SS's Avatar
R4N SS
speak top Steve @ Speedshack
Old Oct 8, 2018 | 10:45 PM
90_spec's Avatar
90_spec
Sweet, perfect answer, Steve is te man!
rsturbolee
Jan 21, 2012 05:07 PM
srlew
Escort MK 5 / MK 6
Jan 27, 2008 03:59 PM
Mk5_XR3i_130
Dec 31, 2006 09:01 AM
Tezla82
Jul 14, 2006 04:50 PM
