Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
Mk4 xr3i mfi bad running
Old Sep 23, 2018 | 06:25 AM
dazrsturbo's Avatar
dazrsturbo
Default Mk4 xr3i mfi bad running
Got a problem with my 89 xr3i cab. 1.6 mfi . I think it’s running rich and it seems to not be getting enough air. If I pull the vacuum pipe off where the cold start valve is on the inlet manifold it runs a lot better due to sucking in more air. Anyone know what could be causing this please and how to resolve. Thanks!
Old Sep 23, 2018 | 03:59 PM
haz87's Avatar
haz87
Mixture is probably out. Fuel pressure could possibly be poor.
Has it had a fuel filter recently? Always worth a punt for Ł20 and definitely wont do any harm
Old Sep 23, 2018 | 05:39 PM
dazrsturbo's Avatar
dazrsturbo
yep it’s had a new pump and changed filter at same time
Old Sep 23, 2018 | 05:52 PM
haz87's Avatar
haz87
Have you had in on a gas analyser to actually check the mixture?
Could also be the WUR (warm up regulator) but without a fuel pressure gauge its pretty difficult to even do basic troubleshooting on the K-Jet system. Easy enough to make your own tho
Old Sep 23, 2018 | 06:03 PM
dazrsturbo's Avatar
dazrsturbo
i havnt no. I’m going to book it in with a local specialist I think. Just wondered if it was something simple I could sort
Old Oct 12, 2018 | 07:29 AM
dazrsturbo's Avatar
dazrsturbo
had and the car looked at by a specialist here and turns out the WUR is knakard. New one getting fitted this weekend
Old Oct 12, 2018 | 07:32 AM
haz87's Avatar
haz87
Cool - they are such an overlooked and misunderstood part. Glad you found a mechanic who knew what they were doing
Old Oct 20, 2018 | 06:58 PM
dazrsturbo's Avatar
dazrsturbo
yeah there’s a chap local here who’s got a lot of knowledge when it comes to the k jet systems, got the old girl running today and it’s sorted.
Escort_Cabbie
Oct 31, 2010 09:40 PM
mato
Feb 8, 2009 05:02 PM
ford crazy
Feb 23, 2006 04:32 PM
