Inlet cam query
Old Sep 22, 2018 | 11:45 AM
cossie2's Avatar
cossie2
Default Inlet cam query
Hi,
Need advice regarding inlet cam for cossie.. Is the bhp 666, Newman 256 and AB07 inlet cam all same or there is a difference.. Anybody runs in their car any of them and if so on what angle they perform best..
Thanks
Old Sep 22, 2018 | 12:17 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
I run the Newman AB07. Timed as standard as per MSD's recommendations on quaife steel pulleys with standard exh cam. It is very very mild so runs exactly as a standard engine. I wanted my engine to retain its sewing machine smooth idle and the AB07 keeps that and helps it breath better mid / top end.
I cant back it up with any technical data but my motor goes well and made 362 @ 21psi on msd rollers on a little tt t35.55 with other supporting mods.
Good cam in my experience but really depends what you want out of it.
i went for it after reading someone else's good experience with it. I think it was steve with the yb xr4i who had good results years ago.
Old Sep 22, 2018 | 02:41 PM
cossie2's Avatar
cossie2
Hi,
Thanks for reply... Can you tell me what was the torque when it was mapped... So timing is as oe cam.. Thanks for info.. I got one myself so i was wondering about timing as i found some info that this one should be timed at 110 and another info 112 deg.. So was not sure
cossie daz
13
Jan 17, 2013 07:21 PM
dom123
Oct 7, 2008 07:31 PM
Nash
Jan 16, 2007 06:36 PM
cosworthbg
Oct 24, 2006 04:29 PM
