Any welders on here for a bit of advice ?
Old Sep 21, 2018 | 05:53 PM
chrisgcombi's Avatar
chrisgcombi
Default Any welders on here for a bit of advice ?
I have a mk6 escort van and was gonna replace the sills. There full sills so what would b the best way of welding them in as they have a cut where the door is then the sill goes into what looks like a crease from the door to the arch how the bloody hell do you weld that and get a nice line ??????????
Old Sep 21, 2018 | 05:55 PM
Caddyshack's Avatar
Caddyshack
Were the originals spot welded and then seam sealed with something like tiger seal?
if not I guess you need to build the weld up and then grind it back flat?
Old Sep 21, 2018 | 06:33 PM
zetaboostboy522bhp's Avatar
zetaboostboy522bhp
Where the original spot welds are drill them out with a spot weld holesaw they are tiny and about £30 from machine mart , pilot them first with a 3 mm drill bit first as it has a centre guide on the holesaw , do all them then measure the new sill which should be larger from the factory so you can trim it down , decide where you are going to cut on the car and go for it but make sure you have enough material on the new sill , get a beefy flat blade screwdriver and tap the whole sill off , mine was pretty easy to get off tbh, clean all the metal as new as possible without taking to much material away as they are very thin especially on the pressed curved sections, clean and paint in the sill that's left on the car ,, trim your new sill and test fit , when your happy it's near perfect either use part of your old sill or make a new metal section that's about 1 inch wide and bend it to match the curves of the original panel then drill , plug weld 1/2 inch on the old panel and 1/2 inch left to weld to the new sill so
1. the sill will fit flushed the original panel
2. You've got something solid to weld against and not just blow holes everywhere
get yourself a 10 mm wild belt sander best tool I own and carefully dress the welds back
then use all the 3 mm holes you've drilled and mount the new sill and mark from behind and drill the new sill with a 6mm hole
most important to clamp as much of the work you can and then plug weld all of the holes up and again dress the back , try and keep the weld as flat as possible as you will have less to grind back.
thats it done simple as lol
Cheers paul
Old Sep 21, 2018 | 08:38 PM
chrisgcombi
Default Weld
Than you guys really appreciate your replies you make it look easy haha . Thanks
don't want to b a pain but on the escorts where the sill goes from under the door to the bottom of car there's a big lip which I can weld to but it's from where the door opens at side to the rear wheel there's a crease line from the door to the back arch . Should I just cut underneath that about half inch then cut sill to suit then weld it in ??????? Thanks again
Old Sep 21, 2018 | 09:10 PM
zetaboostboy522bhp
yes , try and keep it as simple as possible , if there any body panel lines etc and metal work is solid keep it and trim the sill to suit. It was easy getting it off but very hard lining it up right , I won't lies it took me a week of fiddling around to get near perfect , my mate owns a bodyshop and said it would be done in half a day lol
cheers paul
Old Sep 21, 2018 | 10:46 PM
chrisgcombi
Default Weld
Thank you once again for advice . Think I'll try and sort it as your good advice is a real help wish me luck haha . Thanks
ROADWARS
Nov 22, 2010 09:00 PM
rsturbo27
Aug 6, 2010 05:26 PM
Spiky
Jul 29, 2008 10:34 AM
Gra
11
Sep 16, 2004 05:53 PM
