Cosworth speed clock wiring
Old Sep 4, 2018 | 08:54 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Default Cosworth speed clock wiring
Anyone got the pin data or a wiring diagram of the plug that plugs into the back of the speedo cluster on a saff. Taking mine to work next week to do a load of jobs and I’ll be doing some wiring with that plug
Old Sep 4, 2018 | 11:52 AM
Marc sierra's Avatar
Marc sierra
I believe this should be complete:
Brown - mass
black/yellow - switched 12V
green - revs
brown/green - oil pressure
blue - alternator
brown/black - fuel gauge
brown/white - coolant temperature
brown/yellow - brake fluid switch/handbrake
black/white - indicator left
black/green - indicator right
grey/green - lighting
black/white - main beam indicator
Old Sep 4, 2018 | 12:56 PM
ajamesc's Avatar
ajamesc
Brilliant I can work with that cheers
Old Sep 5, 2018 | 07:29 AM
cossynut2's Avatar
cossynut2
10 Year Member
Brown - mass
green - revs
blue - alternator
You are the man Marc, you always have such helpful information.
Old Sep 5, 2018 | 12:48 PM
Marc sierra
Thanks! Glad I could help.
Old Sep 12, 2018 | 01:11 PM
R4N SS's Avatar
R4N SS
Brown - mass
green - revs
blue - alternator
Should be easy to wire in a custom dash with that info - top info as always mate
Old Sep 12, 2018 | 05:16 PM
ajamesc's Avatar
ajamesc
Brown - mass
green - revs
blue - alternator
do you have a diagram or was that from memory? That list has 2x black/white on it but there’s only one on the car
Old Sep 13, 2018 | 05:41 AM
Marc sierra
I have the diagram. I believe the left and right indicator wires are joined at the instrument cluster, as there is only a single light for both indicators.
Old Sep 13, 2018 | 08:23 AM
ajamesc's Avatar
ajamesc
I’ll have to check with the power prob and the dash. There’s only one black/white with in the plug the list has two.
curt randerson
Ford Escort RS Cosworth
Jun 27, 2017 07:07 PM
Zetecfiesta
Oct 19, 2006 09:50 PM
APB-RSTURBOVELOPMENTS
Feb 11, 2006 08:49 AM
luke89
Jan 31, 2006 11:43 PM
