Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Engine swap
Old Sep 1, 2018 | 06:43 PM
Adam Thomson's Avatar
Adam Thomson
Default Engine swap
Hi everyone, just looking for advice, I have a mk6 1.25 finesse and a mk6 1.4 zetec, the finesse is nearly fecked and I'm looking to swap the engine over as the zetec is lower mileage, is it as easy as swapping the engine, ecu and keys over? What extra wiring needs done? Can the zetec just go straight over? Any help would be great thanks
Adam
Old Jun 23, 2019 | 02:21 PM
fantomcat_2k's Avatar
fantomcat_2k
I have never done this before but yes.. generally they can be swapped over with little or no trouble. It's well known that 1.7 Puma engines swap straiht into most fiestas also.
I can't help you with the actual information itself, but I can point you in the right direction. Look for guides on Puma Engine swaps. Its noted that 2 litre Mondeo engines have been used also.
yogi
Ford Focus Range
Jun 21, 2016 05:46 PM
Bigdaggy123
Ford Focus (All Models)
Feb 1, 2016 03:41 PM
JoeE30
Aug 10, 2004 07:59 AM
Fiesta RS1800/RS Turbo
Feb 11, 2004 10:40 PM
Jan 28, 2004 09:53 PM
