Oppliger cosworth inlet manifold throttle body question
I've just bought an oppliger inlet,I've bolted the throttle body up and need some help with the linkage,I can't find any pictures of how people have connected the throttle cable as it will now be mounted behind the throttle body,does anybody have and pictures of what needs to be done please
There was a picture on Facebook of spec-r making a custom bracket for a fancy manifold. Think I’ll drop mine off there this week as mine don’t move properly and puts the cable at a funny angle. I’ve a hart inlet with a small turbo escort t/b
What's the part like on the throttle body as that's what I'm having trouble with,I need it to pull from behind the throttle body so need a different part that bolts to the throttle body and can sort out the bracket for the cable at a later date
Mines a custom made bracket that was done for the small turbo t/b by joe is it? That makes the heart inlets. But it’s not very good it puts the cable at a bad angle. Needs a proper one making which it why I’ll not fuck about any more spec-r can do it then I know it’s done properly
Few more photos of my set-up
The cable runs nice and staight onto the throttle body.
I had to put an extra bit of heat protecting tube over the cable as it touches the header tank.
1374lee
Mar 28, 2010 01:04 PM
bigryrs
Jul 4, 2009 06:49 PM
Red16
Dec 16, 2004 05:01 PM
