Cork or rubber gasket on Cvh engine
Old Sep 1, 2018 | 10:38 AM
24psi boost's Avatar
24psi boost
Default Cork or rubber gasket on Cvh engine
As above just wondering which type is best to use? And what peoples experience is as to which one seals the best to prevent leaks?
have a genuime ford item fitted at present and always seems to leak!
thanks in advance
Old Sep 1, 2018 | 11:52 AM
Giorgos92's Avatar
Giorgos92
In my experience rubber is far better at sealing than cork. Cork doesn't seem to seal good enough especially on steel valve covers or sumps where its not unusual to have some level of warping going on due to previous abuse. Also for me at least cork doesn't provide as good a feeling when tightening so if youre not using a torque wrench its easier to overtighten the bolts compared to rubber creating said warpage and leaks. In short given the choice I would always prefer to use a rubber gasket.
tlr_rst
Jan 3, 2014 05:53 PM
24psi boost
Sep 23, 2013 03:25 PM
paceo
13
Sep 11, 2008 07:08 PM
pocket_rocket
Aug 27, 2008 07:33 PM
