who uses the rubber rocker cover gasket for the rs turbo cvh engine?
As above does anyone use the rubber cvh engine rocker cover gaskets? are they any better in terms of sealing or stopping the normal oil leaks assoociated with the cork version?
Thanks in advance.
Thanks in advance.
I put a rubber one on my cossie and blew it out on the first test drive.
Oil went everywhere , it's now back together with a cometic and is fine.
Rubber ones are spot on. But i still use a bit of sealent just incase. The corkones just soak up the oil and dont really seem to seal if u are using a thinner oil. But that could also be down to a wonkey rocker cover. Ive never come across a true one.
I found the rubber ones shite on standard cvh covers. Always leaked! (and yes tried payen/ford etc)
Always stuck to cork.
However with the rs1600i rocker cover i now use, the rubber seals fine. But then theres alot more meat on the 1600i cover base so probably just doesnt warp like the tin covers
