What yb spark plugs
Old Aug 24, 2018 | 04:23 PM
mattman1234's Avatar
mattman1234
Default What yb spark plugs
Probably been done hundreds of times,What are the YB plugs to use.
Currently use ik27's. One has gone down,so will be replacing,same or are there better ones out there.
Old Aug 25, 2018 | 07:30 AM
2Litre's Avatar
2Litre
What power are you running? I would not change the ones you are using IK27 if your output is anywhere from 300 to 400bhp. They truly are the best plug on the market in my opinion.
Cheers.
Tim.
Old Aug 26, 2018 | 02:28 PM
costina's Avatar
costina
Live long and prosper!!
Why has one died? If you have a dodgy cylinder it can foul a denso easily.
Old Aug 26, 2018 | 04:19 PM
mattman1234
Ive been messing about with the the afr's/closed loop settings.
looked fine though,same as all the others.
Stuck some olds ngk's in at mo.Not missing a beat
.Ik27's ordered.
Old Aug 26, 2018 | 05:01 PM
costina's Avatar
costina
Fair enough they don't like a rich mixture.
Old Aug 27, 2018 | 05:59 PM
cossie2's Avatar
cossie2
I lost a tip on one of those...never had better idle,drive..car had good working map... so now back to motorcraft as i am afraid to use them again..
Old Aug 27, 2018 | 06:41 PM
mattman1234
Don't say that !!
Did it make much mess
Kris84
Jun 30, 2017 01:09 AM
Mike Rainbird
Trader Parts for Sale.
13
Apr 16, 2004 08:08 PM
Mar 16, 2004 08:12 PM
Feb 28, 2004 08:05 PM
Jan 21, 2004 08:55 PM
