What yb spark plugs
What yb spark plugs
Probably been done hundreds of times,What are the YB plugs to use.
Currently use ik27's. One has gone down,so will be replacing,same or are there better ones out there.
What power are you running? I would not change the ones you are using IK27 if your output is anywhere from 300 to 400bhp. They truly are the best plug on the market in my opinion.
Cheers.
Tim.
Cheers.
Tim.
mattman1234 (25-08-2018)
Ive been messing about with the the afr's/closed loop settings.
looked fine though,same as all the others.
Stuck some olds ngk's in at mo.Not missing a beat
.Ik27's ordered.
.Ik27's ordered.
