Xr3i mfi no spark
Old Aug 15, 2018 | 11:04 AM
Scott Clark's Avatar
Scott Clark
Default Xr3i mfi no spark
Hi i have a 89 xr3i cab that first of all i had trouble starting when warm now it won't even start cold ive check the pump all seems good ive checked and there is no spark at the plugs could anyone help before i start putting on new bits.
Old Aug 15, 2018 | 11:41 AM
haz87's Avatar
haz87
You just need to work backwards. Is there spark at the distributor cap?
Take the king lead off and check if that is sparking to earth. If it does, then the coil is fine, and the fault lie at the cap/distributor (the ignition modules love to die - and the caps/rotor need to be clean internally)
If the kind leads doesnt spark - then its potential coil or col wiring. Again, easily checked with a basic multimeter
Old Aug 16, 2018 | 10:16 PM
Scott Clark
Thanks for your help i changed the module and she is running great.
Escort_Cabbie
Oct 31, 2010 09:40 PM
mato
Feb 8, 2009 05:02 PM
ford crazy
Feb 23, 2006 04:32 PM
