Cosworth 4x4 oil dipstick part number
Old Aug 13, 2018 | 07:34 PM
McCloud 85's Avatar
McCloud 85
Default Cosworth 4x4 oil dipstick part number
As title, I need to double check I have the right dipstick for the engine. I’m
assuming there is an allowance for the filter arm on the 4x4, as I’m having some funny oil readings between cold and recently run.
Thanks
Old Aug 13, 2018 | 08:43 PM
Caddyshack's Avatar
Caddyshack
I don’t know the answer but there is a thread on here somewhere about the correct way to measure and I THINK it may have been hot due to the amount of oil the head holds?
Old Aug 14, 2018 | 08:56 PM
McCloud 85's Avatar
McCloud 85
Yeah this might be the case as if I fill it to max when stone cold then run the car and measure within 5 mins or so of stopping the engine, the oil will read very low towards and below min. Top it up to full at this point and when cold for some time (days/week or so) it will read 5/6mm over max. Not bothered just want to make sure the right dipstick is being used and the engine isn’t being forced to breathe heavy.
Old Aug 15, 2018 | 07:07 AM
St3V3_C's Avatar
St3V3_C
Read it cold only.
Keep it in the middle, not at max.
Never above max when cold.
Old Aug 15, 2018 | 01:44 PM
charlie luciano's Avatar
charlie luciano
I had a look on catcar there are two sticks showing first finis number is 6052015 -28/02/1990 which I guess would be the 2wd one then the other finis is 6542379 01/02/1990-31/12/1995 which should be 4x4
Attached Thumbnails Cosworth 4x4 oil dipstick part number-4b43a166-ae90-49bc-b097-855e1d1f9613.png   Cosworth 4x4 oil dipstick part number-75fa315a-3410-4097-83ef-9bb12c22f078.png   Cosworth 4x4 oil dipstick part number-78f9a278-52d6-4659-ab1e-d243eb7f58fe.png   Cosworth 4x4 oil dipstick part number-52a5d4db-c464-4356-a2c0-4aaa26dac4f9.png
Old Aug 16, 2018 | 09:30 PM
McCloud 85's Avatar
McCloud 85
Thanks for the responses guys. Reading the oil is fine when cold, just seems to be very low when run and checked 10 mins or so later?
Thanks for part numbers? Inow realise I need to figure out the stamped number on the dipstick itself, can anyone tell me if this is correct for a 4x4?
Old Aug 17, 2018 | 06:46 AM
St3V3_C's Avatar
St3V3_C
Well of course it will be low after 10mins - the oil is all still up in the engine!
Old Aug 17, 2018 | 07:32 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
Check your oil level every time you fill up with petrol
Old Aug 17, 2018 | 08:02 AM
McCloud 85's Avatar
McCloud 85
So this would be check when warm after 5-10 mins once filled up and paid etc and ignore any cold reading back home in the garage?
Old Aug 18, 2018 | 09:16 AM
Turbosystems
Super Moderator
Just check the level after a minute or 2, engine oil levels are designed to be checked and set in normal operational use
Mark V8
Feb 10, 2017 08:23 PM
sharps218
Nov 29, 2008 07:33 PM
Cola
Oct 27, 2006 04:51 PM
Richie.
May 29, 2006 12:58 PM
