Ford Nouveau Red - Primer colour??
Old Aug 6, 2018 | 06:12 AM
qed296's Avatar
qed296
Default Ford Nouveau Red - Primer colour??
Hi all,
Got a jacking point cover to spray.
It's a black plastic part.
Spray colour is (Hycote) Ford Nouveau Red Metallic.
I've tried a few websites but no listing for what colour primer to use.
Any ideas folks??
Old Aug 6, 2018 | 07:31 AM
cossynut2's Avatar
cossynut2
10 Year Member
Originally Posted by qed296
Hi all,
Any ideas folks??
Standard grey primer should be fine.
Old Aug 7, 2018 | 08:57 AM
qed296's Avatar
qed296
Ok, I only asked as I cought an episode of gas monkey and they struggled to match a green.....they tried a different primer and it matched.
Just seems odd there's no listings for the primer.
I'll give it ago.
Old Aug 8, 2018 | 11:41 PM
xr_craig's Avatar
xr_craig
Grey will be fine as long as it’s covered properly. If your that worried use a red primer
Old Aug 9, 2018 | 07:13 AM
cossynut2's Avatar
cossynut2
10 Year Member
I'll give it ago.
You may need to finish it with clear coat as its metallic.
Old Aug 9, 2018 | 04:34 PM
qed296's Avatar
qed296
Grey primer applied.....
Old Aug 9, 2018 | 07:51 PM
qed296's Avatar
qed296
Couple of coats of colour....looks good wet...see what it's like after a few hours in the heat.
Old Aug 9, 2018 | 09:36 PM
cossynut2's Avatar
cossynut2
10 Year Member
I am not sure if its just your photo but to me it looks like you have missed some small bits which are still showing the grey primer.? Make sure you cover all over the parts. You must still have some paint left in the can .Aerosol spray painting can result in a top finish,take your time and you should be pleased with the end result. Restored this old Honda motorbike, all re-painted with aerosols.
Old Aug 9, 2018 | 09:49 PM
qed296's Avatar
qed296
Must be the light/photo....there well covered both sides.
Sprayed many a thing with cans and got really good results.
As with most things it's in the prep, primed, flatted it out..tack wiped..etc...
painted this with an old can I found in my dad's old garage years ago.
Chassis hight mock up
Old Aug 10, 2018 | 08:43 AM
cossynut2's Avatar
cossynut2
10 Year Member
Nice one, must have been the light when you took the photo, seems like you are spot on with your aerosol painting.
Old Aug 10, 2018 | 09:21 AM
RichieST's Avatar
RichieST
You can get great results with aerosols, I've painted quite a few bits before. As said though it's all in the prep and take your time!
qed296
Aug 12, 2018 06:37 AM
cutch
12
Jun 3, 2013 05:35 AM
fordsportjay
Apr 13, 2006 03:24 PM
fordsportjay
Apr 1, 2006 07:32 PM
