Side skirt clip (correct order?)
Old Aug 1, 2018 | 11:21 AM
qed296's Avatar
qed296
Default Side skirt clip (correct order?)
Set about sorting my clips and have received a set this morning.
look really good, but as most of mine are missing just want to check I've got them set out correct.
Having done a search on here there's mixed posts about how many of which size goes where.
ref : 1x sml (f) 5x med (m) 2x lrg (r)
ref : 4x sml (f) 1x med (m) 3x leg (r)
I actually have : 3x sml (f) 1x med (m) 4x lrg (r)
No dout the combo I've received is correct but just wondered how others have got on.
Old Aug 1, 2018 | 02:36 PM
costina's Avatar
costina
Live long and prosper!!
Looks right and I think that's how I done mine.
Old Aug 1, 2018 | 04:16 PM
qed296's Avatar
qed296
One side finished in 18mins....
really happy with these.
Old Aug 1, 2018 | 04:30 PM
costina's Avatar
costina
They are really good.
spray some clear wax around them.
I also used copper grease on all the grub screws.
Old Aug 1, 2018 | 07:04 PM
qed296's Avatar
qed296
Well what a pig the o/s was!!
It had got wood screws and metal collets along with flat head screws holding it in place, only solution take the skirt off completely.
Nearly 2hrs to sort. Managed to find the last bag of rivets I had for the skirt top.
Old Aug 2, 2018 | 12:24 AM
robrs2's Avatar
robrs2
The clip order is from the front: Small on front wing, 3 small on front of long skirt, Middle at the middle of skirt and 4 long at the rear.
I made some new ones. Screw on insted of rivet on.
Tired with a rivet on one also.
Old Aug 2, 2018 | 05:01 AM
qed296's Avatar
qed296
Are those plastic moulded or 3d printed?
I did look at some on ebay, plastic moulded but for Ł75 the chances are they will break either when fitting or later down the line.
I think the extra for the ones I went with will be worth it in the long run.
Old Aug 2, 2018 | 09:08 PM
robrs2's Avatar
robrs2
All plastic will break in time. There are loads of plastic clip all over the car. These are Polyethlene fairly flexible, even more if warned up. I didnt fancy scewing metal ones onto the sill and breaking the paint, causing rust.
RScrew69
Jan 25, 2009 08:56 PM
tregmatt
11
Jul 14, 2008 09:56 PM
fish99
Ford Escort RS Cosworth
May 27, 2007 09:13 AM
MATCOS
Oct 19, 2005 03:09 PM
