Borg Warner+ 72lbs siemans
Old Jul 29, 2018 | 05:08 PM
cozzy jeff's Avatar
cozzy jeff
Default Borg Warner+ 72lbs siemans
Going Borg warner 7064 next year,would siemans 72lb injector be suitable to make the most of the turbo?
Old Jul 29, 2018 | 05:39 PM
Caddyshack's Avatar
Caddyshack
I have 1000 cc Siemens if that helps?
Old Jul 29, 2018 | 06:08 PM
cozzy jeff's Avatar
cozzy jeff
no that doesnt help at all😂
are you on aftermarket mangement though?
im staying with L8,just wondering if 72's will flow enough fuel to get the best out of the turbo.
Old Jul 29, 2018 | 07:19 PM
Mark Shead's Avatar
Mark Shead
72lb are good for 500hp ish give or take a bit a 7064 is good for 520 to 530hp
Mark
Old Jul 29, 2018 | 07:25 PM
Adam-M's Avatar
Adam-M
Mark
what supporting mods do you need to make 520/530 with a 7064 mark? Would an engine with standard ports but bigger inlet manifold and uprated inlet cam make this?
Old Jul 29, 2018 | 08:11 PM
Mark Shead's Avatar
Mark Shead
477hp is most I have seen on a stock engine and a hart inlet. I did one with cams but the owner crashed the car before I got to see what Hp it makes.
On a ported head and cams I have seen 521hp and 535ftlb.
Mark
Old Jul 29, 2018 | 08:27 PM
cozzy jeff's Avatar
cozzy jeff
Mark
thanks for the info Mark ,the head will be ported/polished and matched inlet with rs500 plenum and throttle body,havent thought about cams yet🤔
Old Jul 29, 2018 | 08:49 PM
3drRich's Avatar
3drRich
Hello Jeff, got used to the power already lol. Personally I would go Siemens 83lbs if you can get a set then your covered. Sod's law I sold a set 2 weeks ago.
Old Jul 29, 2018 | 08:50 PM
3drRich's Avatar
3drRich
Did you say you have a rs500 inlet plenum Jeff?
Old Jul 29, 2018 | 09:01 PM
cozzy jeff's Avatar
cozzy jeff
when karl mapped it he said the engine was a little tired,i have a 200 block here and a 4x4 head coming my way so engine build time,finding a set of 83's for decend money is the hard part rich,just like them damn fog light grills😂
its had a 500 inlet on it since its been back on the road mate,ive had i tucked away for some years now.
Old Jul 29, 2018 | 09:23 PM
3drRich's Avatar
3drRich
There was a set of fog light grills on the rs500 Facebook page last week for £70 and sold instantly. Even these seem to be creeping up in price since the last time I spoke to you.
Old Jul 29, 2018 | 09:36 PM
cozzy jeff's Avatar
cozzy jeff
set on ebay recently went for 271 quid,wish id bought them ones off you now😠
Old Jul 30, 2018 | 04:54 AM
Adam-M's Avatar
Adam-M
they where replicas aswell
Old Jul 30, 2018 | 09:29 AM
3drRich's Avatar
3drRich
We've all wished that at some point Jeff especially when the rs tax just keeps rising. There was another set on there last week that where on for about 2 mins and disappeared.
Old Jul 30, 2018 | 09:53 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Do they not do an alternative or can you not use bigger and just not use them to there full potential
Old Jul 30, 2018 | 11:54 AM
cozzy jeff's Avatar
cozzy jeff
tbh james i dont know,ive managed to get set of new 72's for half the price of a set of second hand 83's,and if 72's flow enough for 500 bhp ill be happy with that.
Old Jul 30, 2018 | 11:56 AM
ajamesc's Avatar
ajamesc
fair play
Old Jul 30, 2018 | 05:36 PM
turbotrev's Avatar
turbotrev
I would run 83’s if going for around 500hp.
You could always fit 72’s and have it mapped then see if they are still fueling enough?
if you do max them out just drop the boost back a bit until you can get hold of 83’s
Cheers Paul
Old Jul 30, 2018 | 06:59 PM
sierrafun's Avatar
sierrafun
72lb for 500 + and 83lb for 650 max
Old Jul 30, 2018 | 08:13 PM
Jan300's Avatar
Jan300
I have same but P8 ecu setup and running 67% of the injectors opening time at 1.8 bar and is too rich fueling.
Old Jul 30, 2018 | 10:35 PM
20/20 vision's Avatar
20/20 vision
From: it's not where you are, it's where you've been and where you hope to be
can't you run high impedance injectors on cosworth low imp ecu?
loads of new big high impedance injectors cheap these days
Old Jul 31, 2018 | 07:54 AM
sierrafun's Avatar
sierrafun
yes you cant run need progamapped ecu ,,cheap injectors are siemens deka long ones
Old Jul 31, 2018 | 09:30 PM
cossynut2's Avatar
cossynut2
10 Year Member
I have Siemens Low impedence 83lb injectors in my 2wd Saff. I had to change to an L8 ecu with a MSD driver baby board. To run any of the modern high impedence injectors you need an up to date ECU.
Old Jul 31, 2018 | 09:32 PM
20/20 vision
what's a progamapped ecu?
have you actually tried running high imp injectors on weber marelli or are you just guessing?
most ecu's designed for low impedance injectors can happily drive high impedance injectors just fine.
Old Jul 31, 2018 | 09:41 PM
cossynut2's Avatar
cossynut2
10 Year Member
Not on a Cosworth YB .L8 /P8 ecu will run Low impedence injectors only.
Old Jul 31, 2018 | 09:50 PM
20/20 vision
i think it will and would be interested to hear from anyone who has tried it rather than 'hearsay'
Old Aug 1, 2018 | 07:15 AM
cossie51's Avatar
cossie51
I fancy a BW 7064 on mine once it's up and running again but will have to wait as spent far to much money on it already this year with management, brakes, and wheels.
My only worries are cracking the block as I have the ARP stud and nut kit fitted and don't fancy an engine build just so I can change turbo so need to investigate this more.
Old Aug 1, 2018 | 10:08 PM
turbotrev's Avatar
turbotrev
wow, I didnt know 83’s would fuel 650hp!
Cheers Paul
Old Aug 2, 2018 | 07:03 AM
cossynut2's Avatar
cossynut2
10 Year Member
Cheers Paul
I thought from what other people are using, 1000cc injectors would be needed for 650bhp.
marco polo
Oct 12, 2005 09:28 AM
devilac
May 7, 2005 06:55 PM
agus RS
Dec 20, 2004 09:01 PM
Jan 18, 2004 04:48 PM
