high compression ratio for cosworth engine what octane gas?
Old Jul 26, 2018 | 02:32 PM
sierrafun's Avatar
sierrafun
Default high compression ratio for cosworth engine what octane gas?
as above who of you run 8.8 cr ratio and bigger cr in cosworth engine ?what gazoline you use ?is safe at 95 octane ?need more ?
Old Jul 26, 2018 | 09:27 PM
Mark Shead's Avatar
Mark Shead
More info needed such as turbo what boost and power you are planning to run also what intercooler. And what ecu you running.
Mark
russ rs
May 22, 2011 01:19 PM
dake205
Jan 19, 2010 06:33 PM
PJay
Technical essay Archives
202
Oct 12, 2008 02:10 AM
essexrsturbo
30
Nov 25, 2005 07:31 PM
extra14
Jun 18, 2005 01:07 PM
