Focus ST170 Xenon headlights - direct replacement?
Old Jul 24, 2018 | 10:54 AM
jimwise68's Avatar
jimwise68
Default Focus ST170 Xenon headlights - direct replacement?
are the Xenon headlights for the ST170 a direct replacement?
If I buy some do they fit straight in or is there any modifications to the electrics that need doing?
Old Jul 24, 2018 | 12:24 PM
RichieST's Avatar
RichieST
They will plug in but not power up as the looms are quite different. For a full install you will also need the self levelling system and headlamp washers.
Old Jul 24, 2018 | 12:28 PM
costina's Avatar
costina
Live long and prosper!!
Yes they do work but the self levelling don't. And as said you won't have washers.
Steve 1PD will be able to give a more detailed answer.
There is also a sensor on the dash.
Old Jul 24, 2018 | 01:44 PM
jimwise68's Avatar
jimwise68
cheers, thanks for the replies
Old Jul 24, 2018 | 01:58 PM
RichieST's Avatar
RichieST
Sensor on the dash is for the climate control
Old Jul 24, 2018 | 03:21 PM
STeve's Avatar
Super Moderator
no mate its a light sensor it combines with the sensors on the front wishbone etc one of them things ubless you was looking for it you would never see it, Btw Jim I have pristine xenons for sale but sadly collection only
Old Jul 24, 2018 | 03:59 PM
jimwise68's Avatar
jimwise68
No good 1-PD if they don't plug and play
Old Jul 24, 2018 | 04:24 PM
RichieST's Avatar
RichieST
You mean the sensor that sits on the dash with a purple disc on top? That's the sun load sensor for the climate control. It has nothing to do with the headlights.
Old Jul 24, 2018 | 04:39 PM
costina's Avatar
costina
I am now confused.
Old Jul 24, 2018 | 04:57 PM
STeve's Avatar
Super Moderator
on the wiring diagram it says it has dual purpose for headlights,climate so I guess were both right lol
Old Jul 24, 2018 | 04:59 PM
STeve's Avatar
Super Moderator
what many do is move the wire in the plug so it enable manual headlamp adjustment as the xenons are way better than the halogens for sure
Old Jan 11, 2021 | 08:24 AM
Ber23's Avatar
Ber23
Default Install in mk1.5
Could you please help me to turn on my xenon headlights of my focus mk1.5? I have the headlights of a focus st170, how do I adapt the connectors? Thank you!!
Old Feb 23, 2022 | 08:25 PM
Steve, nottingham's Avatar
Steve, nottingham
Default Re pinning xenon plug
Hi Steve,
would there be any chance that you could help me with the information regarding moving the pins, and which wires need splicing and/or bridging. I know how to get the pins out if they need changing. I’m just not having much luck in finding a reliable guide from somebody that has changed from a halogen to oem xenon set up.
Many thanks in advance, and any help will be greatly appreciated.
Thanks. Steve,
BATMAN7007
Jun 13, 2011 06:50 PM
drsrst2zvh
Feb 3, 2011 06:53 PM
chappa
Oct 11, 2010 05:57 PM
stroker762
Aug 3, 2006 08:50 PM
tessatony
Jan 23, 2006 09:45 PM
