Fiesta rs turbo started running lean
Old Jul 16, 2018 | 08:03 AM
DanSWfez's Avatar
DanSWfez
Default Fiesta rs turbo started running lean
Hi guys and girls, iv had the fez for 8 years ands it been fine but a few months back just started running lean and had a few ideas from people but nothing is working i had a 195 chip and injectors removed all back to standard but still lean. Also sprayed brake cleaner to find air leaks. Anyone had this or have any ideas what i would be? very gratefully to any help thank Dan.
Old Jul 16, 2018 | 10:17 AM
Mad_Mat's Avatar
Mad_Mat
New Owner
My best internet keyboard warrior guess is either Fuel pump. Fuel pump wiring or fuel pressure regulator gone bad. Good luck
Old Jul 16, 2018 | 03:54 PM
DanSWfez's Avatar
DanSWfez
Thanks mad mat, iv tryed new pump and had pressure tested all ok ill try find another reg and look at wiring got to worth a go 👍
Old Jul 17, 2018 | 09:59 AM
matthart's Avatar
matthart
How do you know it's running lean? Got a well calibrated wideband?
Old Jul 17, 2018 | 08:10 PM
DanSWfez's Avatar
DanSWfez
Put it on a rolling road to see what he could do but he wonldnt touch it said it was lean as fook and I need to sort it first, he did say fuel pressure was good. Most garages dont have a clue even ford lmfao one charged me 180 and said it was the earth and they had sorted it but temp is still flyin up with little throttle think they just want to plug it in and let the computer do the work. Went all through the wiring with a multimeter and cheaked fuses and relays. Just read on hear about engine temp sensor under inlet they sometimes dont break just send it crazy will have one tomorrow let you know. 👍👍
Old Jul 18, 2018 | 12:00 PM
DanSWfez's Avatar
DanSWfez
Rolling road told me, was told at ford it needed setting up
Old Jul 18, 2018 | 12:02 PM
DanSWfez's Avatar
DanSWfez
Seen something about the engine temp sensor under the inlet on here goin to try it later
Old Jul 18, 2018 | 12:06 PM
DanSWfez's Avatar
DanSWfez
Checked wiring and fule pressure will try map sensor after this, garage charged me 180 saying it was bad earth but dint fix it
Old Jul 19, 2018 | 08:48 AM
DanSWfez's Avatar
DanSWfez
Sorted! It was the sensor on the underneath of the inlet
JamesH
17
May 24, 2013 10:38 AM
RS-adam
Aug 9, 2010 12:19 AM
abdr500
Mar 22, 2005 06:52 PM
DaveEscos
18
Feb 7, 2005 02:02 PM
Alvyn
Dec 18, 2004 07:47 PM
