Mondeo 16" alloy tyres
Old Jul 10, 2018 | 10:53 AM
Carlitos's Avatar
Carlitos
Default Mondeo 16" alloy tyres
I picked up a set of Mondeo 16" alloys, the cossie look-a-likes, which came with tyres 205/55/16. I tried fitting these last night and expected them not to fit, which they didn't. Fronts were just ok but rear were rubbing on the arch, tyres way too big. So I need to buy smaller tyres.
The alloys I have are 6.5J ET40. I've read on here some people saying 195 is best and others saying 205, mix that up with some Mondeo alloys being 6.5J and other 7J and I'm proper confused. Anybody had experience with this alloy and got any recommendations. Originally I was looking at Toyo Proxes 205/45/16 but now I'm not sure. Cheers!
Old Jul 10, 2018 | 02:47 PM
geordiegooner's Avatar
geordiegooner
For What Car
I'd go for 195 45 16 if there rubbing on arches though the tyres not as wide as the 205 will be
Old Jul 10, 2018 | 03:35 PM
Carlitos's Avatar
Carlitos
Escort mk4 '89.
Yes, good point. Width of the tyre wouldn't change the arch rubbing when under load regardless of profile/hight. I guess a bit of arch rolling might solve it.
One job I do need to do which will affect this, I need to un-lower the rear or at least bring it closer to what it should be. Previous owner stuck some springs on it which has dropped it quite a lot (but only the rear). Too much for my liking.
Old Jul 10, 2018 | 05:45 PM
geordiegooner
If it's the height of the tyre that's causing the rubbing then you need to change the height profile so to a 40 or a 35
Old Jul 10, 2018 | 10:01 PM
slammedorion's Avatar
slammedorion
195 45 or 40 will be fine
Old Jul 11, 2018 | 12:37 PM
Carlitos's Avatar
Carlitos
Thanks both. I was quite set on 205's but you've convinced me the safer option is 195. I've placed my order already.
mk1 rst
Aug 19, 2012 02:33 PM
chrisholmes23
Insurance
Jan 16, 2012 09:37 AM
FlashBastd
Alloy wheels and ICE for sale
Oct 5, 2009 10:01 AM
Adam1
Mar 10, 2007 08:31 PM
Azrael
Ford Escort RS Cosworth
Jun 18, 2004 09:21 PM
