Sierra Cosworth 4x4 Earth pionts/tale and dash
Old Jul 7, 2018 | 08:29 AM
paalrosen's Avatar
paalrosen
Default Sierra Cosworth 4x4 Earth pionts/tale and dash
Does anyone know where there are grounding points on this car.
Have seen many who think where things are, but not so many who know for sure.
I know it's ground to the engine / gearbox. But not so much more.
There are probably many points that often fail, but where do they sit?
I have the classic problems with the rear lights, which go mental with the signal lights on. My question, where is this grounded? then I can check orginal earth points before anything else.
When I put on full main lights, the oil lamp/abs light idicator begins to glow
God knows how I solve this problem, but I will think it's bad Eart somewhere
Does anyone know where to look?
Old Jul 7, 2018 | 02:55 PM
4x4kiwi's Avatar
4x4kiwi
According to the wiring diagrams, there are the following earthing points.
G-1002 - Battery support
G-1003 LH Headlamp mounting panel
G-1004 RH Headlamp mounting panel
G-1017 Main Earth - Bracket steering column support
G-1018 Radio Earth - Bracket steering column support
G-1019 Electronic Earth - Bracket steering column support
G-1020 Tailgate
The three on the steering column support bracket I think from memory you can see if you remove the instrument cluster. I am not sure without looking if it is 3 separate connections, or if they all go to one point. The headlight ones are on the flat panel under the headlights and you can follow the battery connection to the one on the battery support. The one labeled tailgate - I am not sure about on a sapphire but I suspect perhaps the boot lid. Incidentally the taillight wiring shows as earthing to the main earth on the steering column - not the tailgate earth. I can only see this earth used for the luggage compartment lamp and switch, Heated rear window circuit including switch and the tailgate ajar sensor used for the alarm and the doors open display by the clock. Hope this helps. David
Old Jul 7, 2018 | 03:46 PM
4x4kiwi's Avatar
4x4kiwi
Thinking about your specific problem, I think the first thing to check would be for a good contact for the earth connection at the tail light multi plugs. These should be Brown wires. David
Old Jul 8, 2018 | 11:04 AM
paalrosen's Avatar
paalrosen
Thank you very much, I will take a look at the pionts on my car
bull-turbo
Oct 13, 2014 12:44 PM
billybigspuds
Jul 7, 2010 04:55 PM
Gaz 88
Jan 30, 2008 05:35 PM
messcortmk6
28
Sep 9, 2007 06:02 PM
Denial
Jun 28, 2005 05:24 PM
