2012 transit cutting out at idle
just happened yesterday, when the van comes to idle it started cutting out .engine malfunction light on along with srs light and the rev counter stopped working.when you strt it back up it goes as normal.it cut out about 20 times yesterday but only twice today
anyone any ideas?
anyone any ideas?
Are the revs irattic at idle?? There us a fuel pressure switch on the back of the fuel pump that could cause your fault. The switch is held on with 2 Allen key bolts. Easy to change.
RS500
Oct 12, 2012 08:07 AM
shozzacozzie
Jun 4, 2010 09:52 PM
