4x4 cos rear calipers where to buy?
Old Jun 9, 2018 | 03:48 PM
IanC's Avatar
IanC
Default 4x4 cos rear calipers where to buy?
I’ve been after a set with carriers for a while just can’t seam to find any 4x4 ones with carriers I’ve tried all the breakers I can think of no joy
Old Jun 9, 2018 | 03:55 PM
Marc sierra's Avatar
Marc sierra
Calipers from a Granada mk3 estate and Scorpio estate are the exact same and easy to find.
Old Jun 9, 2018 | 07:37 PM
stevieturbo's Avatar
stevieturbo
C**t
I think Ultima rears were vented too ? the ugly granada
Old Jun 9, 2018 | 10:50 PM
Mark V8's Avatar
Mark V8
These ones have TVR tax instead of Cosworth tax !
https://www.ebay.co.uk/itm/2001-TVR-...cAAOSw4BNajpWZ
Old Jun 9, 2018 | 10:55 PM
stevieturbo
C**t
for them selling complete calipers and discs, and to be fair the calipers look in reasonable condition, it's probably not a ridiculous price
Old Jun 10, 2018 | 07:51 AM
The Youth.'s Avatar
The Youth.
those discs on the ebay link won't fit a 4x4 cos,
Steve
Old Jun 10, 2018 | 08:01 AM
Mark V8's Avatar
Mark V8
Steve
Calipers should be the same though if I remember correctly, the guy might do a deal without the discs.
Old Jun 10, 2018 | 09:41 AM
martysmartie's Avatar
martysmartie
Calliper's are easy enough, the carriers you would probably need from the said Granada (or frog-eye Scorpio)
Martin
Old Jun 10, 2018 | 09:46 AM
stevieturbo
C**t
Wouldnt really make sense for TVR to have used different carriers though.
Just adds cost to them for no good reason.
Old Jun 10, 2018 | 10:44 AM
IanC's Avatar
IanC
Martin
That’s the one I’m struggling for carriers calipers are quite easy to get there going on a focus rs mk1 with cossie big discs so I’ll have to make some adaptor plates anyway they don’t have to bolt up to a cossie beam tbh
Old Jun 10, 2018 | 10:47 AM
stevieturbo
C**t
Carrier is a fairly simple item...I guess if there was a market for them, wouldnt be too hard for someone to knock a few out on a CNC.
Whether the market is big enough to support that cost though...is another matter. Could probably even be done in alloy, only caveat being the slider holes might benefit from a steel insert
Old Jun 10, 2018 | 07:21 PM
Mark V8's Avatar
Mark V8
I'm 99% sure the whole caliper/carrier assembly is the same on a TVR with vented rear discs
Old Jun 11, 2018 | 03:33 AM
dojj's Avatar
dojj
Resident Wrestling Legend
You will need the vented disc calipers
They are 20mm thickness not the 10mm of the normal ones
They also came on the Granada estates too
Old Jun 11, 2018 | 08:13 AM
The Youth.'s Avatar
The Youth.
mk3 Granada Cosworth use the same calipers and carriers
tvr carriers will be the same aswell
Steve
Old Jun 12, 2018 | 07:24 AM
AJC's Avatar
AJC
I have some 4x4 rear discs, also have calipers and carriers too
Old Jun 12, 2018 | 10:22 AM
IanC's Avatar
IanC
How much you after for them pal?
MT-Motorsport
18
Apr 3, 2013 07:35 PM
AJ-RST1
Sep 13, 2009 06:15 PM
Sonic Boom
11
Dec 9, 2008 10:13 PM
Jasesapphy
11
Oct 8, 2008 07:29 PM
rabmc
Jun 9, 2005 05:51 PM
