Sapphire Cosworth - Service or Not ?
Old Jun 9, 2018 | 11:50 AM
denniswynott's Avatar
denniswynott
Default Sapphire Cosworth - Service or Not ?
Just pulled my Sapph out again for it's annual MOT and run round the block and was wondering about getting it serviced.
Silly question it may be but it's done just over 1000 miles since the last service and cam belt change....... but that was back in 2009!
It sits stored in a garage other than the odd occasion when it comes out but wonder if I should get it serviced, oils filters and all and a cam belt too perhaps ?
What do you reckon ? It drives fine and seems to have no issues but just wondered what you chaps think ?
Oh, and any recommendations for a Cosworth specialist near Colchester would be good too ?
Regards,
DW.
Old Jun 9, 2018 | 01:06 PM
Giorgos92's Avatar
Giorgos92
I would do an oil change with oil filter and a cambelt change so not a full blown service per se just the most essential items for the engines health. New brake fluid would be nice too as it tends to absorb moisture over time which lowers its boiling point and could be unsafe after 9 years. Maybe some new tires and an alternator belt depending on condition.
Old Jun 9, 2018 | 03:08 PM
The Youth.'s Avatar
The Youth.
as said, I would do a full fluid and belt change
brake fluid, oil, coolent etc
Steve
Old Jun 9, 2018 | 07:25 PM
Fartblood's Avatar
Fartblood
Erect Member
It's gonna need the lot. The only thing that doesn't degrade with time are the spark plugs and air filter.
if they tyres are over 6 years old then you need to think about replacing them too.
Old Jun 10, 2018 | 09:24 AM
martysmartie's Avatar
martysmartie
For the cost the belt is good piece of mind, I don't personally buy the whole oil and moisture thing.
Brake fluid, as mentioned is hygroscopic (absorbs moisture) and anti-freeze looses it's protection/corrosion inhibitor ability over time.
Martin
Old Jun 10, 2018 | 12:13 PM
Fartblood's Avatar
Fartblood
Erect Member
I studied fuels and lubes for my post grad degree. I very much buy into the moisture thing.
Old Jun 10, 2018 | 12:22 PM
thebigmacmoomin's Avatar
thebigmacmoomin
Brake fluid is also tested on the MOT now.
Old Jun 10, 2018 | 03:17 PM
gcfcos's Avatar
gcfcos
Only a visual check for contamination.
Old Jun 10, 2018 | 05:07 PM
costina's Avatar
costina
Live long and prosper!!
Cam belt yes 4k rebuild
Tyres yes it's a quick car and life matters
Brakes and fluid as above.
Safety first.
Old Jun 10, 2018 | 09:53 PM
cossynut2's Avatar
cossynut2
10 Year Member
1000 miles in 9 years!!! There is'nt much chance of wearing it out!!
Old Jun 11, 2018 | 12:24 PM
costina's Avatar
costina
You say that I know of a 35k from new and needed a full engine build due to being shunted about and not properly used.
Old Jun 12, 2018 | 07:01 PM
1374lee's Avatar
1374lee
Yep I know the car Paul, cossieS just don't like being left in the garage, they need to be used.
CheeRS Lee.
n13los
Oct 4, 2009 07:57 PM
Elvis
Jul 1, 2009 06:32 AM
simoncrowe
Oct 25, 2005 09:15 PM
uk_christophe
Feb 5, 2005 06:41 PM
