Looking for help.
Old Jun 9, 2018 | 07:31 AM
jimhc's Avatar
jimhc
big jc
Default Looking for help.
I'm wanting to check my idle control valves wiring. Could someone give advice how to check them with a volunteer. Also what ecu pins do you check to set up a throttle position sensor and what reading to look for thanks for any help.
Old Jun 9, 2018 | 07:40 AM
oldford's Avatar
oldford
Before anyone can answer the question about the setup of the throttle position sensor, we need to know what kind of ecu you have. The setup differs for different ecu's.
Old Jun 9, 2018 | 07:43 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Have a look on this site mate, lots of good information on here and has all the pinouts and also tells you what the readings should be
http://www.bigturbo.co.uk
Old Jun 9, 2018 | 07:49 AM
jimhc's Avatar
jimhc
big jc
Sorry it's a 2wd. Thanks for the link will get stuck in at it when I get home thanks again.
s1cab
Jul 12, 2008 11:29 AM
cossie-nutter
Nov 27, 2006 12:15 PM
mondeomark
Ford Classics & Vintage
Apr 28, 2006 02:15 PM
mondeomark
Fiesta RS1800/RS Turbo
Feb 23, 2006 08:25 AM
