just seen this, are these fiqures really achievably?
Old May 31, 2018 | 07:45 PM
st220kyle's Avatar
st220kyle
Default just seen this, are these fiqures really achievably?
Seem optimistic especially on standard ecu
https://ebay.co.uk/itm/Ford-Fiesta-Z...-/282978708276
Old May 31, 2018 | 08:00 PM
I bet that goes like fook. Well that's if the power figure is correct.
Old May 31, 2018 | 08:27 PM
st220kyle's Avatar
st220kyle
Yeah that's what i was thinking, I've got a zetec s tucked away in the garage crying out for something like that to be done to it
Old Jun 5, 2018 | 01:29 PM
R4N SS's Avatar
R4N SS
i loved my puma engined zetec-s - i bet that goes well with that charger too
Old Jun 5, 2018 | 05:09 PM
I'm just a bit confused how it is running on a standard ecu..
Old Jun 6, 2018 | 11:16 AM
R4N SS's Avatar
R4N SS
obviously been jailbroken or hacked or whatever you want to call it. Similar to people mapping cossie ecu's
Old Jun 7, 2018 | 06:37 AM
Fartblood's Avatar
Fartblood
Erect Member
Probably not so hard to do for a supercharger, as the pressure is a direct linear function of engine speed. Unlike a turbo, which fluctuates.
Old Jun 7, 2018 | 10:33 AM
This is what I was thinking. Would the ecu not need to know the supercharger air pressure??
Maybe matey.
Old Jun 7, 2018 | 11:40 AM
Caddyshack's Avatar
Caddyshack
I expect that by the fact the advert says "could do with a standalone ECU" it probably doesn't run perfectly. My friend turboed a VR6 golf on a budget and he just added a load of fuel pressure, upped the injectors and got some dodgy solder in chip off the net...it was a right old bodge but the car was still very quick, it just didnt drive well.....
I wonder if someone has bodged it enough OR does this ECU run closed loop as standard and maybe has compensated a bit to alow the extra fuelling etc.?
Old Jun 7, 2018 | 12:41 PM
Fartblood's Avatar
Fartblood
Erect Member
yarp, the mass airflow sensor will give a fair approximation.
Old Jun 8, 2018 | 01:35 AM
visa_broke's Avatar
visa_broke
10 Year Member
Probably done the old american trick of a rising rate pressure reg to chuck more fuel in when it comes on boost.
KW-rscos
Aug 21, 2009 06:34 AM
mad_max926
Jun 17, 2009 10:41 PM
_DAN_
Jan 30, 2007 04:45 PM
COSSIE 1
Mar 25, 2006 10:25 AM
