Hub splines very tight
I’m rebuilding the rear hubs and mate the two splines on inner and outer hub
The splines go about half way down and it gets very tight
Almost like it’s tapered
Is this normal it don’t seem right
Pic of hub I’m on about
Thanks
Thanks
Hi mate
Yep there spotless
I’m sure they will go fully home but with slot of force
They were difficult to get off tbh
Had to hit with s copper mallet to shift
It’s the same both sides
Yep there spotless
240 what F or C ? 240f would be fine, make sure you baste it every 5 mins and add some ground black pepper to taste and some potatoes
Make sure your wife is not in, better still use your neighbour's oven. You could simply just sit it in a pan of boiling water
I did put my 944 Bell housing in the dishwasher and she spotted that!
Mind you it does depend if your dishwasher is a hotpoint or a Heather
Doh
Sep 30, 2005 04:40 PM
CraigN
15
Dec 21, 2004 02:09 PM
