Hub splines very tight
I’m rebuilding the rear hubs and mate the two splines on inner and outer hub
The splines go about half way down and it gets very tight
Almost like it’s tapered
Is this normal it don’t seem right
Pic of hub I’m on about
Thanks
Thanks
Hi , as Marc has already stated ,I don't believe they are tapered. I know that mine also needed a a gentle tap to separate along with a binding halfway down there mating travel.
Best.
Tim.
Best.
Tim.
How did you get them back on
Did the binding you had actually stop them from sliding fully home
It looks like they will need a lot of force
Can you check the splines are fully clean on the drive shaft and the hub with a small wire brush then copper lube
Hi mate
Yep there spotless
I’m sure they will go fully home but with slot of force
They were difficult to get off tbh
Had to hit with s copper mallet to shift
It’s the same both sides
Yep there spotless
Super Moderator
240 what F or C ? 240f would be fine, make sure you baste it every 5 mins and add some ground black pepper to taste and some potatoes
Make sure your wife is not in, better still use your neighbour's oven. You could simply just sit it in a pan of boiling water
I did put my 944 Bell housing in the dishwasher and she spotted that!
Yeah thought about that
But it will damage the oil / grease seal
But could put the outer in the freezer
Doh
30-09-2005 04:40 PM
CraigN
15
21-12-2004 02:09 PM
