2WD drive shafts
Old May 20, 2018 | 12:40 PM
timsrs's Avatar
timsrs
Default 2WD drive shafts
They look exactly the same both ends
But can someone confirm if they should be fitted a certain way round
Thanks
Old May 22, 2018 | 02:54 AM
2Litre's Avatar
2Litre
Morning ,
They are exactly the same both ends so as a result you can fit as you wish. But if a shaft has been driven in certain way i.e. - turned anti-clockwise it's life you should fit it the same way as the structure of the metal will be stressed / set in that direction.
Hope this makes some sort of sense.
Tim.
Old May 22, 2018 | 06:17 AM
timsrs's Avatar
timsrs
Hi
Yes it does
Thanks
bluebones
Jan 16, 2011 06:29 PM
zetaboostboy522bhp
Nov 12, 2009 09:48 PM
brooksy
Mar 26, 2007 05:58 PM
kennert
Sep 26, 2004 07:26 PM
