Old school RS1600i running problem. HELP !
Old May 18, 2018 | 07:46 AM
RetroTed's Avatar
RetroTed
Default Old school RS1600i running problem. HELP !
So it's a standard car with twin coils and it's misfiring and spluttering under acceleration, popping back through the exhaust. Replaced inlet gaskets, plugs, checked and cleaned the gearbox pick up, no obvious air leaks, vacuum pipe to ecu is working, all earths are good and now i'm at my witts end
It was running iffy before xmas and it turned out to be the inley gaskets, changed these and she was running well until recently
If you hold the revs @ 2500 rpm it's misses like the timing is out if that makes sense and it seems to be running rich
Can anyone shed any light on what to check pls
Old May 18, 2018 | 10:58 AM
gcfcos's Avatar
gcfcos
Have u changed the ht leads mate? They could be breaking down
Old May 18, 2018 | 11:41 AM
haz87's Avatar
haz87
Checked the fuel pressure and CO? K-Jet can easily get out of tune, more so if it sits for long periods.
Old May 19, 2018 | 06:17 AM
cossynut2's Avatar
cossynut2
10 Year Member
Hope you get it sorted, if not you can always buy the one being advertised for Ł97,000!!!!!
Old Nov 18, 2018 | 06:01 PM
Sietyneandwear's Avatar
Sietyneandwear
Mine was doing that. Tried another ecu and it’s sorted it. Had to try 4 different ones to find a working one
Old ford
64
Nov 12, 2013 05:07 PM
Oranoco
11
Nov 17, 2009 06:14 PM
p_jay78
15
Mar 17, 2006 02:35 PM
Carl160180
Jan 29, 2005 09:08 PM
