Fired up after 4 years dead
Posted a few queries on here over my overhaul that grew arms and legs, thought I'd update. Owned the car 23 years now.
Finally got the engine/wiring completed, cranked it over to get the oil pressure up, fuel relay back in, wouldn't fire. Was expecting hours of fault finding after the amount of work I've done and the time it's been 'dead', but, hadn't put the alarm fuse back in.....re-fitted, brum, straight away. Chuffed to say the least. Bit more to do before I get it MOT'd etc but at least it's running again. My 8 year old son can't remember it working.
Short list of work:
Sump removed & modified for breather return
New big ends & mains (whilst it was in bits, didn't really need them)
New oil seals everywhere
New AP organic clutch & ARP flywheel bolts
New Autodynamix engine/fan/fuel pump looms
L8 ECU, Siemens blacks and new MSD chip to suit
New starter & battery
New cam belt & tensioner
New Collins engine mounts
New Vibratechnics gearbox mount
Trouble is, all the time it's been off the road, I honestly haven't missed it. Been running a 996 turbo for the last 3 years and an E46 M3 prior to that so the Cossie has become somewhat redundant. Hoping driving it again will put a smile on my face, and be good to give it a run against it's stablemate
Haven't found any for sale to get an idea of it's value these days either, any pointers?
Short list of work:
Result that matey. Cossies are going for stupid money these days. Sadly so are the price of parts.
Hopefully when you drive it again you will fall in love with it again.
As Toby said good 2wd saffs are above 20k.
400bhp in a saff is great fun without the added expense. Just hope you new clutch can handle it.
Enjoy and have fun you will deffo have a smile.
It was 300 ATW before I took it apart.
It's running a T34.48, on the advice of MSD I've swapped out the injectors (along with loom etc) as above so should be north of 350. It was a handful before in anything but bone dry conditions.
Bit of perspective, changed a spring on my Mam's 1.2 Fiesta the other week, it's on 195 tyres as std, the Saff is on 205s FFS.
Should give the 996 a fright up to about 120, at which point engineering takes over...
Well I am on a T34.48 and over 400 and 400 lbft but I am running 2.3bar peak.....
What tyres you running and are they still ok? Safety first eh esp with little ones to think about.
Its sat on very old 17 Yokohamas which will be getting binned and reverting to the std lattice rims. Got 2 sets of those, 6 have 888s on but open to suggestions for a good road tyre? Toyo always used to be decent.
fordsportjay
20
Mar 21, 2006 06:52 PM
24
Jul 9, 2005 01:22 PM
