Gasket needed between block and PAS bracket?
Old Apr 25, 2018 | 01:05 PM
rog's Avatar
rog
Default Gasket needed between block and PAS bracket?
Putting my engine back together, not done one of there’s for about 10 years, do I need a gasket between the pas bracket and the block, I’m thinking yes??? (2WD)
Old Apr 25, 2018 | 02:03 PM
Caddyshack's Avatar
Caddyshack
My answer would be no BUT if you look behind that braket (two big posts) there is the old Pinto fuel pump take off, some blocks are blanked and others need a plate over that oval shaped bit with 2 bolt holes....my last 200 block had a plate over there and that DID have a gasket...I am sure a smear of make your own gasket sealer would be fine.
Old Apr 25, 2018 | 02:43 PM
costina's Avatar
costina
Live long and prosper!!
Gasket sealer will be fine. But if you really wanna gasket then Burton's will sell a pinto fuel pump gasket.
job done either way.
Old Apr 25, 2018 | 02:52 PM
rog's Avatar
rog
Thanks for the replies, I shall seal it up just in case. You’ve jogged my memory about the fuel pump, I was wondering what it was for, knew it was some sort of casting design left in that was redundant in cossies.
Old Apr 25, 2018 | 03:05 PM
Caddyshack's Avatar
Caddyshack
corrected my post to fuel pump......not oil
L1AM_RS
Jan 8, 2014 06:31 PM
Pudnpepsi
Apr 30, 2012 07:25 PM
Jasesapphy
Jun 21, 2008 06:42 AM
Stavros
33
Aug 15, 2006 10:28 PM
Stavros
11
May 26, 2005 05:01 PM
