It was not the 3 bar map censer
Old Apr 23, 2018 | 07:46 PM
COLEYST200's Avatar
COLEYST200
Default It was not the 3 bar map censer
well about two weeks back I was having running problems with my focus cosworth and I really fort it was the 3 bar map censer that was at fault . Well I stuck at it doing tests
and iv got to the bottom of it . And I'm glad to say iv now sorted it and it cost a massive £15 it was the blue censor .
The car was spot on when cold but when it got hot that's when it started over fauling big time witch started me thinking. A bit of a pain to do as my setup is not standard and with having the WRC breath on made it very hard to get to but I did it and it's running spot on now
Old Apr 23, 2018 | 09:24 PM
Adam-M's Avatar
Adam-M
Glad you’ve got to the bottom of it those water temp sensors cause all sorts of havoc, good job they’re cheap ehh.
Old Apr 23, 2018 | 09:41 PM
Ridgey's Avatar
Ridgey
Old Apr 24, 2018 | 01:47 PM
My saff was similar to the fault you had. It was ok doing 50 60 mph. As soon as I got into town traffic and the engine temp got hot the car would misfire and run like a bag of shit.
Old Apr 24, 2018 | 08:13 PM
COLEYST200's Avatar
COLEYST200
It did my head in as I would start it up from cold and it ran spot on . I would drive it down the lane and it ran spot on still then the moment I would give it some stick it would go sick . It was not till I got it back home and I fort I would have to send it in to be mapped.
So I come in the house for a cup of tea . Well 15 min had gone by I went back to the car and it started up spot on and drove spot on then it hit me that the water temp was low . So I did a bit of research and read up about this blue censer could do this so i popped into GGR as there only down the road from me £15 job done .
So all I can say to any one that has a fuelling
problem change this censer first as it could be fault and if it's not the problem then it was only £15
Old Apr 25, 2018 | 10:33 AM
cosmatt's Avatar
cosmatt
Pretty much how my mk1 was behaving. Worth noting that there are new "not so good" blue cts sensors about online too.
Old Apr 26, 2018 | 01:27 PM
martysmartie's Avatar
martysmartie
Yep, just like the MAP sensor (which can have serious consequences).
Martin
bazpro
Sep 23, 2011 10:58 AM
Carter
Dec 5, 2006 07:40 PM
Ollie MK5 Turbo
Mar 29, 2006 12:24 PM
abdr500
24
May 19, 2005 10:43 AM
