The world's most annoying rattle
Old Apr 22, 2018 | 04:04 PM
Deagle's Avatar
Deagle
Default The world's most annoying rattle
As above
I own a mk2 st running mod x rs on bc racing BR coilovers with literally every bush and arm replaced except the rear trailing arms as ford and dreamscience told me they look fine.
So literally any uneven road surface I'm getting an annoying tapping noise coming from the back end I've checked everything I can and tightened everything I could see and the knock is still present ... As said above everything is brand new so I am completely at a loss
I also have another knock from the front, I had the car on an mot ramp and when pulling on the drivers side inner tie rod it knocked and moved about 1mm, the arm was replaced about 1000 miles ago so it's still mint..
anyone in the Bradford/Halifax area want to give me some help
much appreciated
as you can see the car is well looked after and has been built to a well rounded spec so I havnt missed anything or neglected anything
Old Apr 22, 2018 | 05:13 PM
GVK.'s Avatar
GVK.
Not something simple like boot latch is it?
Old Apr 22, 2018 | 05:41 PM
Deagle's Avatar
Deagle
ive tried some tape on that too to around where it hooks around the latch, but from the drivers seat it sounds like its coming from the passenger rear side buddy
Old Apr 22, 2018 | 05:45 PM
costina's Avatar
costina
Live long and prosper!!
Heat shields , spare wheel Jack and brace?
what about handbrake cables give them a wiggle as most knock on the brackets and or underside.
Old Apr 22, 2018 | 06:01 PM
Deagle's Avatar
Deagle
heatshields are gone as those were also hanging off, the st3 has a flat floor so i dont have a spare or a jack, ill look at those handbrake cables thats something i havnt checked, but it does sound like it could be suspension related ...
Old Apr 22, 2018 | 06:50 PM
nthorpey's Avatar
nthorpey
loose bump stops in shocks?
Old Apr 22, 2018 | 07:21 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
My track 911 used to make this sort of noise after we used more solid suspension mountings etc...it turned out to be the shocks moving as normal...the sound was lost when rubber was in the setup, the mounts just transmitted the sound.
Old Apr 22, 2018 | 08:24 PM
Deagle's Avatar
Deagle
so what do you suggest? ive used oem bushes and arms, nothing fancy
Old Apr 22, 2018 | 08:28 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
You just need to keep changing stuff and trying things until you find it and consider a specialist who may have experienced it before
Old Apr 22, 2018 | 08:29 PM
Deagle's Avatar
Deagle
ill have to try some aftermarket arb links and possibly some aftermarket trailing arm bushes first ... bloody cars
Old Apr 22, 2018 | 09:07 PM
Smithys cab's Avatar
Smithys cab
Had this on my 2010 ST it was the rear drop links
Old Apr 22, 2018 | 09:36 PM
visa_broke's Avatar
visa_broke
10 Year Member
off topic but is that the stock inlet manifold or aftermarket?
Old Apr 22, 2018 | 09:37 PM
GVK.'s Avatar
GVK.
I have seen on mk2 Focus where the actual ARB needs replacing as it's worn out where the D bushes sit.
Old Apr 23, 2018 | 04:23 AM
Deagle's Avatar
Deagle
it's the airtec one it's basically the same as autospecialists pal
the rear links are brand new too and feel tight when I've pulled on them or tried rocking using my pry bar, could be the bar it does look poor condition literally a mm of play sounds like it's flapping around in the wind when suspension is involved
Old Apr 23, 2018 | 05:58 AM
STeve's Avatar
Super Moderator
as mentioned the ARB can be a culprit as changed mine to the whiteline kit and cured my rattles etc
stewarthannah
Mar 1, 2023 02:48 PM
kandyman
Ford XR Range
Mar 24, 2014 08:20 PM
robmorris
Ford Focus ST
Jul 9, 2013 10:31 AM
StephTell
100
Jul 25, 2008 08:53 PM
paceo
55
Aug 8, 2007 01:53 PM
