The world's most annoying rattle
Old 22-04-2018, 04:04 PM
Deagle
Deagle's Avatar
Default The world's most annoying rattle
As above
I own a mk2 st running mod x rs on bc racing BR coilovers with literally every bush and arm replaced except the rear trailing arms as ford and dreamscience told me they look fine.
So literally any uneven road surface I'm getting an annoying tapping noise coming from the back end I've checked everything I can and tightened everything I could see and the knock is still present ... As said above everything is brand new so I am completely at a loss
I also have another knock from the front, I had the car on an mot ramp and when pulling on the drivers side inner tie rod it knocked and moved about 1mm, the arm was replaced about 1000 miles ago so it's still mint..
anyone in the Bradford/Halifax area want to give me some help
much appreciated
as you can see the car is well looked after and has been built to a well rounded spec so I havnt missed anything or neglected anything
Old 22-04-2018, 05:13 PM
GVK.
GVK.'s Avatar
Not something simple like boot latch is it?
Old 22-04-2018, 05:41 PM
Deagle
Deagle's Avatar
ive tried some tape on that too to around where it hooks around the latch, but from the drivers seat it sounds like its coming from the passenger rear side buddy
Old 22-04-2018, 05:45 PM
costina
Live long and prosper!!
costina's Avatar
Heat shields , spare wheel Jack and brace?
what about handbrake cables give them a wiggle as most knock on the brackets and or underside.
Old 22-04-2018, 06:01 PM
Deagle
Deagle's Avatar
heatshields are gone as those were also hanging off, the st3 has a flat floor so i dont have a spare or a jack, ill look at those handbrake cables thats something i havnt checked, but it does sound like it could be suspension related ...
Old 22-04-2018, 06:50 PM
nthorpey
nthorpey's Avatar
loose bump stops in shocks?
Old 22-04-2018, 07:21 PM
Caddyshack
Caddyshack's Avatar
My track 911 used to make this sort of noise after we used more solid suspension mountings etc...it turned out to be the shocks moving as normal...the sound was lost when rubber was in the setup, the mounts just transmitted the sound.
Deagle (22-04-2018)
Old 22-04-2018, 08:24 PM
Deagle
Deagle's Avatar
so what do you suggest? ive used oem bushes and arms, nothing fancy
Old 22-04-2018, 08:28 PM
Caddyshack
Caddyshack's Avatar
You just need to keep changing stuff and trying things until you find it and consider a specialist who may have experienced it before
Old 22-04-2018, 08:29 PM
Deagle
Deagle's Avatar
ill have to try some aftermarket arb links and possibly some aftermarket trailing arm bushes first ... bloody cars
Old 22-04-2018, 09:07 PM
Smithys cab
Smithys cab's Avatar
Had this on my 2010 ST it was the rear drop links
Old 22-04-2018, 09:36 PM
visa_broke
visa_broke's Avatar
off topic but is that the stock inlet manifold or aftermarket?
Old 22-04-2018, 09:37 PM
GVK.
GVK.'s Avatar
I have seen on mk2 Focus where the actual ARB needs replacing as it's worn out where the D bushes sit.
Old 23-04-2018, 04:23 AM
Deagle
Deagle's Avatar
it's the airtec one it's basically the same as autospecialists pal
the rear links are brand new too and feel tight when I've pulled on them or tried rocking using my pry bar, could be the bar it does look poor condition literally a mm of play sounds like it's flapping around in the wind when suspension is involved
Old 23-04-2018, 05:58 AM
Moderator
STeve's Avatar
as mentioned the ARB can be a culprit as changed mine to the whiteline kit and cured my rattles etc
stewarthannah
01-03-2023 02:48 PM
kandyman
Ford XR Range
24-03-2014 08:20 PM
robmorris
Ford Focus ST
09-07-2013 10:31 AM
StephTell
100
25-07-2008 08:53 PM
paceo
55
08-08-2007 01:53 PM
Quick Reply: The world's most annoying rattle
