fuel gauge issues
last time i drove my 4x4 sap a few weeks ago before it went to the paint shop the fuel gauge started playing up. All was fine and well was working fine put petrol in and the gauge registered it then when i braked the gauge went to the bottom below zero, then when i came off the brakes the gauge went to the very top above full and stayed there until i braked again.
Has anyone else has an issue like this i assume its an earth but wanted to see if anyone else had had this problem and what it was as don't want to have to drop the tank unless i absolutely have too.
Maybe worth mentioning that the rev counter has a mind of its own too but i put that down to the plugs on the bulkhead but thinking these problems could be related
Cheers Billy
Cheers Billy
Not the same symptoms but I had my gauge intermittently dropping off a few years back that turned out to be a bad connection in a wiring loom plug in the back of the boot between the tail lights from memory. I removed the plug / socket and soldered the wires and haven't had the problem since. David
rickbartlett
May 19, 2009 06:18 AM
rickbartlett
38
Mar 28, 2009 04:13 PM
