2006 Focus ST2, speedo issues
Old Apr 19, 2018 | 04:08 PM
andrewmctiernan's Avatar
andrewmctiernan
Default 2006 Focus ST2, speedo issues
hi all, as above there's an issue with my ST, the speedo is saying im doing 80 when its actually 30, whats the usual cause? is it a speed sensor? All the other instruments/gauges are fine
cheers
Andy
Old Apr 19, 2018 | 04:25 PM
andrewmctiernan
spoke too soon the gauges have all went loopy
Old Apr 19, 2018 | 06:09 PM
RichieST's Avatar
RichieST
It's probably the cluster at fault however if the battery is old and weak on it it can throw all sorts of weird electrical faults.
Old Apr 19, 2018 | 06:15 PM
andrewmctiernan
So probably be best sending it away too ECU testing or BBA reman
Old Apr 20, 2018 | 08:08 AM
STeve's Avatar
Super Moderator
dead common on these cars cluster faults but do as Richie said first and check battery, once jump started mine and had no accelerator pedal until battery gained some charge
Old Apr 21, 2018 | 04:15 PM
andrewmctiernan
Battery was renewed recently it’s posted off to cluster repairs so fingers crossed
GTR_STU
May 14, 2017 12:55 PM
Trevor Smeaton
Ford Focus ST
Jan 1, 2015 01:08 PM
walshy77
Dec 22, 2012 04:39 PM
ricky_2006
11
Aug 2, 2009 09:19 PM
Spiky
Shows & Track Days
33
May 14, 2006 12:22 AM
