CVH leaking oil where dipstick tube meet block
Old Apr 19, 2018 | 10:29 AM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Default CVH leaking oil where dipstick tube meet block
Hi guys
Got a leak as above.
Firstly how does the dipstick tube come out, and secondly does it have a seal etc that may have perished ? Is it literally a case of screwing it up tighter ?
Old Apr 19, 2018 | 10:44 AM
haz87's Avatar
haz87
Its friction fit so must be pretty bloomin loose if its leaking. That or you have excessive crankcase pressure so its finding the easiest routes out.
Should be able to just pull it out with a tug, clean it up and then put it back in with a drop of loctite near to hold it in place.
Old Apr 19, 2018 | 11:56 AM
Mr S1's Avatar
Mr S1
In there solid mate - no movement at all. I've put some of the green Loctite bearing adhesive round it, see if that solves it. Got a breather kit fitted and been on for years, nothing disturbed for years either so I'm hoping it may just be after 32 years it had a bit of a leak.
dhutch
Jul 3, 2011 05:53 PM
rickbartlett
Apr 3, 2011 02:57 PM
sharps218
Nov 29, 2008 07:33 PM
bonus_boy
Jul 1, 2008 03:22 PM
Richie.
May 29, 2006 12:58 PM
