Transit connect no boost
Hi guys my transit isn’t boosting right! It is 1.8 tddi
it drives perfect with no lights on dash and does have a little smoke ever now and again under high revs!
it drives like there is no turbo to power it, yet u can hear the turbo spinning and whistling when driving! I’ve checked the pipes and replaced the front 2 pipes either side of cooler but it’s still the same!
any ideas lads
any ideas lads
I’d like to know if you sort it because we have a 04 plate connect tddi with similar symptoms it will boost till about 2.5k revs then goes completely flat I’ve checked the turbo and it spins fine, revved it and can hear it and see it has no splits in hoses and the hoses swell where it’s creating boost, I’ve even had the turbo to actuator pipe off and it still won’t boost any harder or past 2.5k ?
I have had all the pipes off and can’t seem to source a leek! I’m guessing there is a pin hole that only appears when under load! I’m gone be replacing all the pipes this weekend
I had all the pipes off mine yesterday and can’t find any leaks even the intercooler is leak free, looks like someone has already fitted the plate for the egr blank. So the search continues here, what about a blocked cat in the exhaust ?
Is there a little actuator on the inlet manifold. It looks a bit like a turbo actuator??? I've had one on the past where the small c clip has fallen off and the actuator rod had come off.
I think this fault might of been on a tdci though.
i had the same problem drove ok up to just over 2 k turbo sound etc after 2 k would go flat and smoke i changed all pipes etc blanked egr off and then found the problem when i took dp off and noticed the actuator was seized put a new one on and all is good now
Sorry for the long delay in reply! Bloody password wouldn’t work and wouldn’t let me reset it.... sorted now. The transit I sold in the end mate. Turned out to be a little hole in the weld of the inter cooler. Replaced it and it was running a lot better
TIFF
Nov 5, 2006 09:45 PM
